Skrevet av Emne: Think PIV4/Classic Leaf battery upgrade  (Lest 3924 ganger)
  • Gold Member
    • Vis profil
Sv: Think PIV4/Classic Leaf battery upgrade
« Svar #15 på: Lørdag 03. November 2018, klokken 17:06 »
Why not use dedicated boat connector like this from Ratio :
https://www.ratio.nl/nl/catalog/marine/inlets/inlets/groups/g+c+a+view
Selger ladeutstyr via http://Elbilhjelpen.no AS
Har hatt Cree SAM og Ciity el
Har for tiden Tesla S85 VW, C1 EVie,  og Berlingo, div. Think og PSA Classic og City 2010 model og Chin 3 hjuler Pickup, Buddy M9 samt Vectric scooter. Kjøpt Fiat X 1/9 for elektrifisering og venter på Sort Solo EV #635, Microlino, og Aptera #2246 og Sølv Monotrazer MTE-150
rzepon
  • Jr. Member
    • Vis profil
« Svar #16 på: Fredag 15. Mai 2020, klokken 21:26 »
Hi
My Think has 93000km age and he want's doing more :-) but battery said passs
What you know about conversion to lithium?
I have 10kWh packet from golf GTE and want use this in my Think, it possible
to change charge ending voltage in orginal charger and BMS? (my packet 48S2P
samsung sdi 2x28Ah)
When I install this battery Think didn't start :-(
start again on 36S2P, what should be do for instalation 48S2P?
Any sugestion
Chris
BauDemo
  • Hero Member
    • Vis profil
    • www.uppladdning.nu
« Svar #17 på: Lørdag 16. Mai 2020, klokken 15:15 »
I have not done this myself, but I think you need to configure the simovert motor controller via siadis program (you would even need a pin?) to think that the high voltage in the battery is ok.
rzepon
  • Jr. Member
    • Vis profil
« Svar #18 på: Torsdag 21. Mai 2020, klokken 11:19 »
BauDemo
  • Hero Member
    • Vis profil
« Svar #19 på: Onsdag 27. Mai 2020, klokken 12:53 »
I have heard that it is not that hard to unlock it...
