Skrevet av Emne: Checkelec  (Lest 36903 ganger)
    • Elmo
Sv: Checkelec
« Svar #135 på: Lørdag 02. Desember 2017, klokken 17:48 »
Som Elektrolux sa: Det er bare å trekke ut en hovedsikring så går lyset av.
Jeg har merket at tenningen bør være av, for hvis ikke så hender det at SOC viser lavere enn den er etterpå.
Tesla Model 3 AWD/FSD 03/2019 - HW2.5 - FW: 2020.36.11   og Seat Mii 2020.
eUp 2015 - solgt.
Steens
Sv: Checkelec
« Svar #136 på: ſøndag 03. Desember 2017, klokken 00:08 »
And regarding the implementation of the function in Checkelec, it's actually difficult: I used mainly the Lexia software to get the existing commands available. And as you said Helge there is nothing like that in Lexia. But that doesn't mean that it's not possible: there may exist hidden commands but how can we find them without any reference ? If you hear about another software able to do that, I can try to decode it ;).
Helge
Sv: Checkelec
« Svar #137 på: Mandag 04. Desember 2017, klokken 14:18 »
Jada, det... fikk jeg med meg  ;D
...men det var et godt tilleggs-tips!  :+1:
2001 Peugeot 106 Electric (hvit) arvet batteripakken til 1998-modellen
2003 Saxo Electrique (sølv)
2003 Saxo Electrique (hvit)
Ex: 1998 Peugeot 106 Electric (grønn) Ny batteripakke i 2009
Helge
Sv: Checkelec
« Svar #138 på: Mandag 04. Desember 2017, klokken 14:21 »
No problem. Now I know a way to clear the light when you do not have a charging socket close by.
Fribom
  • Newbie
Sv: Checkelec
« Svar #139 på: Torsdag 14. Desember 2017, klokken 22:54 »
Hi Steens.
Seems to be a very nice app. Any plans for a IOS version?
B.r. Sigve
Steens
Sv: Checkelec
« Svar #140 på: Fredag 15. Desember 2017, klokken 01:10 »
I plan to try it but the conversion is not easy. A part of the code can be automatically converted but the work on the other part is Huge. So I will try to make the automatic part first and then see  ;).
Additionally, I need to find a Mac computer and an iPhone (because iOS apps can be developped only in Apple environment >:() and that's another difficulty ! ;)
timescape
Sv: Checkelec
« Svar #141 på: Fredag 15. Desember 2017, klokken 19:09 »
Hi Steens.
B.r. Sigve
Hi Fribom,
There is another issue with Apple..
Apple will not connect to a bluetooth device (and OBD2), unless the device is approved by Apple...
Not easy to get a, by Apple, approved ODB2 :)
br.
Steens
Sv: Checkelec
« Svar #142 på: Lørdag 16. Desember 2017, klokken 15:05 »
Some of the OBD2 interfaces like Vgate are said compatible with iOS. That's at least what I can read on some seller websites. But maybe it's another fake information ?  ???
Fribom
  • Newbie
Sv: Checkelec
« Svar #143 på: ſøndag 17. Desember 2017, klokken 15:39 »
Not a big issue. You have a point in Apple not allowing devices to connect on USB. I can buy a cheap Android device when I need this. :)
Grumle
Sv: Checkelec
« Svar #144 på: ſøndag 31. Desember 2017, klokken 13:57 »
I think there is a vertion of the vgate with wifi instead of bluetooth for iOS
Exelent app Steens!!
im not so good with computers, but one thing ive been thinking about lately is the possibillity to use 3-4 rassberry pi "one in each battery box" to monitor each cell. And transfer the information via bluetooth to the phone. If this is a possebillity, do you think it could be integratet in to the app in some way ? :) The dream would be all cells showing like a square with a colour from green to red depending on voltage of each cell :B
« Siste redigering: ſøndag 31. Desember 2017, klokken 14:00 av Grumle »
    • Elmo
Sv: Checkelec
« Svar #145 på: ſøndag 31. Desember 2017, klokken 16:44 »
Såvidt jeg husker var en her på gang med det samme for 2-3 år siden. Men antar det stoppet opp. Du kan jo evt søke/bla gjennom trådene og se om du finner noe ??
EDIT/PS: jeg fant det ikke selv i farten.  Også dumt at gamle vedlegg (bilder) ikke kan sees i forumet for tiden etter siste oppgradering.
« Siste redigering: ſøndag 31. Desember 2017, klokken 18:09 av Elmo »
eUp 2015 - solgt.
Grumle
Sv: Checkelec
« Svar #146 på: ſøndag 31. Desember 2017, klokken 17:13 »
Spennende! Det skal jeg sjekke ut! Takker for tips :)
kretslopp
Sv: Checkelec
« Svar #147 på: Tirsdag 30. Januar 2018, klokken 20:52 »
Thank you Steens for your tremendous work.
Tomorrow night it's time for my first water service done by myself.
Hva er rekkefølgen på vannfylling respektive lading?
På trukkarne på jobbet lader vi først og fyller etterpå.
Og hvor lange tid tar den ladingen?
Helge
Sv: Checkelec
« Svar #148 på: Tirsdag 30. Januar 2018, klokken 21:59 »
Lading først for batteriene/batterivæsken må få høy nok temperatur før man fyller.  Er batteriene kalde vil man få på litt for mye vann. Når batteriene blir varmere enn dette senere ved kjøring og lading vil batterivæsken utvide seg slik at batteriblokkene "renner over" (ut under bilen) så batterivæsken i batteriblokkene tynnes ut fra vannservice til vannservice.
Hvor lang tid ladingen tar avhenger også noe av SOC før du starter å lade!
kretslopp
Sv: Checkelec
« Svar #149 på: Tirsdag 30. Januar 2018, klokken 22:22 »
Er det vanlig eller initial lading først?
Og så fylle vann?
Hadde gjerne hatt en liste med punkter. Tenkte ha bilen inne på jobben min over natten mellom onsdag og torsdag så jeg må bli ferdig i løpet av arbeidsdagens begynnelse. :)
