Skrevet av Emne: Buddy lead batteries to LiFePo batteries change  (Lest 11435 ganger)
Nuno Santos Silva
  • Newbie
    • Vis profil
« på: Torsdag 27. August 2015, klokken 10:28 »
Hei
First of all, I'm sorry to address you all in english but my Norwegian is not that good - I hope you can understand and help me.
I have a Buddy Cityjet6 and we have make some "refurbishment". We've changed the Lead batteries with 24, 3,4v Lithium batteries.
At the same time we add a Battery Management System from Elektromotus.
In order to maintain the the original car-controller (for the speed information, trip, etc) we've "emulate" the presence of the old batteries by tricking the car-controller to see the voltages on the JP2 connector.
The issue I'm having right now is that when I drive the car I often have temporary "blackouts" on the display panel and within 1-2 second it restores.
At the same time, I have the continuous "1 H" alarm error on the display which is the alarm when the batteries were almost dead...on the previous system.
That gives me the idea that the car controller is not "seeing" batteries although the measures on the JP2 connector indicates the proper voltage...
Any help would be appreciate.
Tusen takk
Nuno
petersv
  • Gold Member
    • Vis profil
Sv: Buddy lead batteries to LiFePo batteries change
« Svar #1 på: Lørdag 22. Oktober 2016, klokken 07:49 »
Did you solve this issue?
RoadRunner
  • Hero Member
    • Vis profil
« Svar #2 på: Tirsdag 08. August 2017, klokken 13:48 »
My guess is that you need to simulate 12V from each cell into the Car-controller, otherwise it believes that one (or more) of the cell has too low voltage and needs charging. I have at least observed the same "1H" indication with 2 of the 6 cell pairs defect.
Trondheim
MetroBuddy 2010
Buddy 2009 - "Vesla B13"
Rav4_EV
  • Gold Member
    • Vis profil
« Svar #3 på: Onsdag 09. August 2017, klokken 09:58 »
Hello Nuno,
Your car controller doesn't "see" that your batteries is being charged and updating the capacity. I'm not sure how you charge your Li-ion's but you have two gray cables where the old Zivan charger used to be. These should be connected for you to be able to drive, but open when charging happens.
Also your new charger should be connected to the old REMA charge plug so the charge current passes the measure shunt.
BTW, old car of Manuel?
« Siste redigering: Onsdag 09. August 2017, klokken 10:03 av Rav4_EV »
Arne Magnus Berge 90608080
