Skrevet av Emne: How to switch from 8A to 14A charging with on a 2014 Ion?  (Lest 5691 ganger)
BauDemo
  • Hero Member
    • Vis profil
    • www.uppladdning.nu
« på: Fredag 11. April 2014, klokken 23:02 »
I have this new (to me at least) design of a charging cable that came with 2014 Peugeot Ion.
How do I switch from 8A to 14A charging current?
Apart from the manual stop button there are no other visible buttons.
svingen
  • Gold Member
    • Vis profil
Sv: How to switch from 8A to 14A charging with on a 2014 Ion?
« Svar #1 på: Fredag 11. April 2014, klokken 23:39 »
You need a spesial power core to activate 14, if you have a magnet to the core when you put it in the wall socket it will fool it and enable 14 have i read :)
« Siste redigering: Fredag 11. April 2014, klokken 23:41 av svingen »
Bor i Nittedal (oslo)
BauDemo
  • Hero Member
    • Vis profil
« Svar #2 på: Fredag 11. April 2014, klokken 23:52 »
interesting - I am not sure I understand "core" - should the magnet be close to the box, or close to the shuko plug?
svingen
  • Gold Member
    • Vis profil
« Svar #3 på: Lørdag 12. April 2014, klokken 08:05 »
Schuko plug
pwb
  • Gold Member
    • Vis profil
« Svar #4 på: Onsdag 30. April 2014, klokken 18:41 »
I use a litle magnet from magnetix toys and it works :-) The magnet dont need to be in place after it has detected that its there. As long as the conntact is in the wall its on 14A, you can take out the charger from the car and its still 14A when you put it back in the car.
smedus
  • Newbie
    • Vis profil
« Svar #5 på: ſøndag 21. Februar 2016, klokken 17:19 »
Here is a picture enclosed of a modified 1-to-3 wall adapter where the small magnet is included to switch from 8A to 14A on the charger for Ion / C-zero / iMiev The magnet is from Clas Ohlson. The hole drilled is 10mm.
  • Gold Member
    • Vis profil
« Svar #6 på: ſøndag 21. Februar 2016, klokken 18:15 »
Is the 1-to-3 wall adapter earthed for the Schuko socket? As there is two europlug sockets there this adapter is designed for indoor / dry environment. Not recommended for outdoor use at 14A?
Below is an example of an outdoor Green'up schuco socket with the needed magnet. Unfortunately, these are expensive as I guess they are produced and sold in small quantities:
http://www.nofuel.no/Produkt/greenup-220v-kontakt-
« Siste redigering: ſøndag 21. Februar 2016, klokken 18:18 av TB »
Citroen C-Zero siden 2012 med OVMS - 90 000 km
  • Gold Member
    • Vis profil
« Svar #7 på: Mandag 22. Februar 2016, klokken 08:50 »
Here is the easy and safe metode to set charging current on theese cables.
Simply attach a magnet with tape as shown here: http://elbilforum.no/forum/index.php/topic,25833.0.html
Plug has a temperature sensor, so if charging is interupted, remove magnet for 8A charging, ore use annother socket.
« Siste redigering: Mandag 22. Februar 2016, klokken 09:23 av elektrolux »
Selger ladeutstyr via http://Elbilhjelpen.no AS
Har hatt trimma City El og Citroen AX elektro
Har for tiden VW e-Up, Peugeot P106 og Citroen Saxo, C1 EVie,  og Berlingo nye modellen, div. Think Classic og City 2010 model, Fiat 500 Microvetti, Buddy og Norges eneste Cree SAM og Chin 3 hjuler samt Vectric scooter. Kjøpt Fiat X 1/9 for elektrifisering og venter på Sort Solo EV #635 og Microlino
Daglig leder i elbilhjelpen.no AS. Utleievirksomhet via Nabobil.no, Leieting.no, Avamera.com og Air B&B i tillegg til privat og eget firma. Bytter hus via homeforexchange.com
andy76
  • Jr. Member
    • Vis profil
« Svar #8 på: Mandag 29. Februar 2016, klokken 15:46 »
Do you/anyone have the magnet article number from Clas Ohlson?
Peugeot Ion 2015
Salt-Hv27
  • Jr. Member
    • Vis profil
« Svar #9 på: Tirsdag 01. Mars 2016, klokken 12:43 »
Magnets are also abundandtly available from Geosport.no
C-zero 2016
Grand C4 GrandTourer 2018
3 kW solcelleanlegg på taket
Østfold
65lars
  • Sr. Member
    • Vis profil
« Svar #10 på: Tirsdag 01. Mars 2016, klokken 14:52 »
Hei Salt-Hv27,
Takk for lenken!
Men som en med-"newbie" her, som også har kjøpt (enda ikke levert) en ny C-Zero...
Er veldig nyskjerrig mht. signaturen din, og det med "3 kW solcelleanlegg på taket" - siden har diskutert dette med mange. Dvs - hvorfor kommer ikke disse bilene med solcellanlegg innebygget i taket?
Og dersom du har et slikt anlegg montert på din C-Zero - hvordan funker det?
Er der egne emner for slike ting på dette forumet?
« Siste redigering: Tirsdag 01. Mars 2016, klokken 14:54 av 65lars »
Trilling, bestilt KIA
  • Gold Member
    • Vis profil
    • Ladespesialisten
« Svar #11 på: Tirsdag 01. Mars 2016, klokken 15:14 »
Hei Salt-Hv27,
Takk for lenken!
Fordi man kanskje får ut noe sånt som 100W fra et solcellepanel på taket av bilen. Det monner ikke. Et 3kW anlegg er nok garantert montert på taket av huset ;)
Kjører Tesla X75D fra mars 2017
65lars
  • Sr. Member
    • Vis profil
« Svar #12 på: Torsdag 03. Mars 2016, klokken 15:28 »
Ok, jkirkebo, I "get it."   Kanskje.
Men om sommeren, kommer jeg til å bruke sykkelen, mer enn bilen.
En "vaklende" el-sykkel nå.
Og dersom bilen står parkert, flere dager i uken, i pent vær m/sol - hvorfor "i all verden" har man ikke innebyggede solceller i taket der, som sakte (men sikkert) kan lade opp batteriet  der.
Det var vel egentlig det jeg lurte på.
Og PS - lenken til disse magnetene er:  http://www.gfh.no/geosport/?ec_store=magneter
Tror ikke jeg trenger å kjøpe der, siden jeg har skrudd fra hverandre x antall harddisker, tatt ut magnetene.  Utrolig sterke! ;D
  • Gold Member
    • Vis profil
« Svar #13 på: Torsdag 03. Mars 2016, klokken 23:37 »
Tja - det vil mulig bli aktuelt med innebygde solceller når ulempene og kostnaden oppveg fordelen. Bilindustrien er ikkje kjent for å endre seg så raskt - skjer normalt fyrst når konkurrenter har noko "folket" vil kjøpe - eller pga. krav frå myndigheiter.
Om solceller på taket gir produsenten fordelar (t.d. slik som hybrid idag, der "alle" skal lage bilar med 20-30 km rekkevidde..) kan det fort dukke opp.
65lars
  • Sr. Member
    • Vis profil
« Svar #14 på: Fredag 04. Mars 2016, klokken 14:38 »
Takk skal du ha, TB.
Jeg er bare "fotgjenger-interessert" i alt dette - for det meste nytt for meg.
Så akkurat en ganske strøken 2012 Leaf på Finn, med et lite solcellepanel på seg:
http://m.finn.no/car/used/ad.html?finnkode=72085141
Lars
(som venter spent på sin C-Zero - dvs - at papirarbeid går igjennom.
Bilen står jo allerede registrert på meg, iflg. 2282 :-)  )
