Nissan Long Life Antifreeze/Coolant (Blue) should occur every 75,000 miles (120,000 km) or 5 years which- ever comes first.
NOTE: Mixing any other type of cool- ant or the use of non-distilled water will reduce the recommended service interval of the coolant.
Chassis and Body Maintenance:
Brake Lines and Cables
Visually inspect for proper installa- tion. Check for chafing, cracks, dete- rioration, and signs of leaking. Re- place any deteriorated or damaged parts immediately.
Brake Pads & Rotors
Check for wear, deterioration and fluid leaks. Replace any deteriorated or damaged parts immediately.
In-Cabin Microfilter
Replace at specified intervals. When driving for prolonged periods in dusty conditions, replace the filter more fre- quently.
Steering Gear and Linkage, Axle and Suspension Parts, Drive Shaft Boots
Check for damage, looseness, and leakage of oil or grease. Under severe driving conditions, inspect more fre- quently.
Tire Rotation
Tires should be rotated every 7,500 miles according to the instructions in the Owner’s Manual. When rotating tires, check for damage and uneven wear. Replace if necessary.
Reduction Gear Oil
Visually inspect for signs of leakage at specified intervals.
Off-Road Maintenance
Check the following items frequently whenever you drive off-road through deep sand, mud or water:
● Brake pads and rotors
● Brake lines and hoses ● Reduction gear oil
● Steering linkage
