Tesla powered think
Startet av motorulf, torsdag 27. september 2018, klokken 13:04
BauDemo
The big transformer in the back on cars with Gen1 PCU is for isolation from mains since the charger used in Gen1 PCU is non isolating.
The charger used in Gen2 PCU is Eltek Valere Power charger 3000 and is isolated - so no need for isolating transformer.
I don't think your built in charger (PCU Gen1) will have any issue with charging at 310V.
What is the max and min voltage during charge?
How do you control the closing of contactors and pre-charging? Is it the bms you are using or have you done this custom for this pack?
motorulf
Minimum voltage: 260V
Maximum voltage: 345V
So if i want the built in charger i need to program some sort of control for it.
Like while the voltage is >= 345V, decrease charging pwm (and current) until current is less then a few amps.
Then turn off charging, send end of charge CAN to PCU.
Contactors and precharging are controlled by the simp-bms board.
I need to add CAN-communication for it but all the hardware is there now.
motorulf
If any of you who are reading this are interested, Simp-BMS can control a few other slave boards.
Tom has recently raised the price though... now it is 300 Euro.
But i have had made some PCBs and could sell a few for self cost, if anyone wants to solder.
Currently supported slaves:
-Tesla Model S/X
-Tesla battery modules used in other OEM cars
-VW E-Golf and GTE (no balancing currently)
-Mitsubishi Outlander
-BMW I3 (no temperature or balancing currently)
I know he is working on i-miev code as well (as I asked him to :))
This is NOT an advertisement, i dont even know the guy, but it seems to be a good way to get old packs running in situations they were not intended, which i like  :P
motorulf
Todays job was to extend the wires connecting to the bms slaves.
That took more time then one could expect. 46 wires in total, cut, stripped, extended, soldered, and heat shrinked.
I used heat shrink with glue in it, as an extra safety feature :)
5 hours of work.  haha, maybe i am slow...
Next up is making brackets for holding that 12th module.
BauDemo
Sitat fra: motorulf på fredag 12. oktober 2018, klokken 10:24
The charger control on the Think is via the CAN Bus - I think message 0x305. I think your BMS would need to emit one or more of the following messages with proper content so the PCU knows what is going on: 0x301, 0x302, 0x303.
And it would need to listen to at least 0x311 to know what is going on with the PCU.
What are the HV connectors you are using?
motorulf
Oh yes.  :D
I did not see i could send a voltage command to the charger, i only saw the pwm command.
Sometimes i think I'm blind...   :P
You mean the connectors going thru the BMS-box?
The +/- output is from the zebra BMU.
The other 3 are from a gen1 think PCU.
I am reusing all i can to keep costs down.  :)
motorulf
Does anybody know the pinout for the multi pin connector in the battery bay?
BauDemo
Do you mean the connector to the zebra battery?
All connectors and their pinout you can find in the electrical wiring diagrams.
motorulf
OK, nice to know  :)
Where can one find those diagrams?  :P
motorulf
Hahaha...
Another facepalm situation. I actually had all information i need all along.
I am either stupid or blind, or maybe both...
Here it is anyways:
motorulf
Update and problems
Battery pack is built and is hanging under the car. The car is up on jack stands.
I need to move the cables in the front of the compartment to have space to mount it permanently.
I will look into that when i get the wheels spinning.
The problem is, i don´t get the green car light to shine.
The car is happy with no errors on dash or CAN until i try to turn the key into start / cranking / green car.
Then i get the red wrench warning light.
On CAN i get 0310    00 00 01 which is "PCU shutdown fault".
I suspect that i don't send the messages it needs to start and it expects to see something else.
I am sending 300, 301, 302, 303, 304, 305, 306
These are an exact copy of what the zebra sent when it still worked, except for battery voltage on 301 which is updated with real values.
Is there a way to know why i get PCU shutdown fault?
On the connector in the battery bay i have only connected 12V, ground, key_run, CAN_H, CAN_L.
Maybe it expects something more?
Anybody have a a clue?
BauDemo?
Caspar?
PRensel?
motorulf
I found the fault, once again it was me.
This time i had connected the driver cables to the contactors wrong. The PCU was not receiving any power.
So all you guys with broken zebras, if i can do this - anybody can. Don't let the Thinks die!  8)
Spinning wheels, green car, happy hippie guy :P
Here is a trace file from a working zebra think, from key off, to driving, and back to key off. if anybody needs it.
I know i would have needed it 2 years ago  :D
I had to cut it down to make it fit in the max 50000 characters, but its all repeating stuff anyways.
;$FILEVERSION=1.1
;$STARTTIME=43353.7676477662
;   C:\Users\torulf\Documents\think start.trc
;   Start time: 2018-09-10 18:25:24.767.0
;   Generated by PCAN-View v4.2.1.533
;   Message Number
;   |         Time Offset (ms)
;   |         |        Type
;   |         |        |        ID (hex)
;   |         |        |        |     Data Length
;   |         |        |        |     |   Data Bytes (hex) ...
     1)         2.6  Rx         0300  8  03 0B 0E 4D 44 02 01 00
     2)         2.9  Rx         0306  8  00 00 00 00 00 00 00 00
     3)        22.9  Rx         0301  8  00 00 0D AA 00 6D 0A BE
     4)        63.0  Rx         0302  8  00 00 00 00 0E 37 00 00
     5)       103.3  Rx         0303  8  0E 37 00 00 00 00 01 00
     6)       143.1  Rx         0304  8  00 00 00 00 0A AB 0A D1
     7)       183.3  Rx         0305  8  00 00 00 00 00 02 00 00
     8)       223.0  Rx         0301  8  00 00 0D AA 00 6D 0A BE
     9)       263.1  Rx         0302  8  00 00 00 00 0E 37 00 00
    10)       303.4  Rx         0303  8  0E 37 00 00 00 00 01 00
    11)       343.2  Rx         0304  8  00 00 00 00 0A AB 0A D1
    12)       383.5  Rx         0305  8  00 00 00 00 00 02 00 00
    13)       423.3  Rx         0301  8  00 00 0D AA 00 6D 0A BE
    14)       463.3  Rx         0302  8  00 00 00 00 0E 37 00 00
    15)       503.8  Rx         0303  8  0E 37 00 00 00 00 01 00
    16)       543.5  Rx         0304  8  00 00 00 00 0A AB 0A D1
    17)       583.7  Rx         0305  8  00 00 00 00 00 02 00 00
    18)       623.3  Rx         0301  8  00 00 0D AA 00 6D 0A BE
    19)       663.5  Rx         0302  8  00 00 00 00 0E 37 00 00
    20)       703.9  Rx         0303  8  0E 37 00 00 00 00 01 00
    21)       743.7  Rx         0304  8  00 00 00 00 0A AB 0A D1
    22)       783.8  Rx         0305  8  00 00 00 00 00 02 00 00
    23)       823.7  Rx         0301  8  00 00 0D AA 00 6D 0A BE
    24)       863.7  Rx         0302  8  00 00 00 00 0E 37 00 00
    25)       904.1  Rx         0303  8  0E 37 00 00 00 00 01 00
    26)       943.8  Rx         0304  8  00 00 00 00 0A AB 0A D1
    27)       983.9  Rx         0305  8  00 00 00 00 00 02 00 00
    28)      1003.5  Rx         0300  8  03 0B 0E 4D 44 02 01 00
    29)      1003.9  Rx         0306  8  00 00 00 00 00 00 00 00
    30)      1023.7  Rx         0301  8  00 00 0D AA 00 6D 0A BE
    31)      1063.9  Rx         0302  8  00 00 00 00 0E 37 00 00
    32)      1104.3  Rx         0303  8  0E 37 00 00 00 00 01 00
    33)      1144.1  Rx         0304  8  00 00 00 00 0A AB 0A D1
    34)      1184.2  Rx         0305  8  00 00 00 00 00 02 00 00
    35)      1224.1  Rx         0301  8  00 00 0D AA 00 6D 0A BE
    36)      1264.1  Rx         0302  8  00 00 00 00 0E 37 00 00
    37)      1304.5  Rx         0303  8  0E 37 00 00 00 00 01 00
    38)      1344.2  Rx         0304  8  00 00 00 00 0A AB 0A D1
    39)      1384.4  Rx         0305  8  00 00 00 00 00 02 00 00
    40)      1424.1  Rx         0301  8  00 00 0D AB 00 6D 0A BE
   238)      4246.2  Rx         0311  2  00 00                               ##########KEY ON
   239)      4246.5  Rx         0263  6  00 00 00 8A 02 00
   240)      4259.1  Rx         0210  7  FF FF 30 68 90 00 34
   241)      4259.3  Rx         04B0  8  27 10 27 10 27 10 27 10
   242)      4267.2  Rx         0302  8  00 00 00 00 0E 37 00 00
   243)      4273.1  Rx         0210  7  FF FF 30 68 90 00 35
   244)      4273.3  Rx         04B0  8  27 10 27 10 27 10 27 10
   245)      4287.1  Rx         0210  7  FF FF 30 68 90 00 36
   246)      4287.4  Rx         04B0  8  27 10 27 10 27 10 27 10
   247)      4301.1  Rx         0210  7  FF FF 30 68 90 00 37
   248)      4301.4  Rx         04B0  8  27 10 27 10 27 10 27 10
   249)      4307.0  Rx         0303  8  0E 37 00 00 00 00 01 00
   250)      4312.0  Rx         0023  1  40
   251)      4312.2  Rx         0460  8  03 E0 00 00 C0 00 00 00
   252)      4315.1  Rx         0210  7  FF FF 30 68 90 00 38
   253)      4315.4  Rx         04B0  8  27 10 27 10 27 10 27 10
   254)      4329.1  Rx         0210  7  FF FF 30 68 90 00 39
   255)      4329.4  Rx         04B0  8  27 10 27 10 27 10 27 10
   256)      4343.1  Rx         0210  7  FF FF 30 68 90 00 3A
   257)      4343.4  Rx         04B0  8  27 10 27 10 27 10 27 10
   258)      4346.2  Rx         0310  3  00 00 00
   259)      4346.5  Rx         0264  8  00 00 00 00 00 00 00 00
   260)      4346.9  Rx         0304  8  00 00 00 00 0A AB 0A D1
   261)      4357.2  Rx         0210  7  FF FF 30 68 90 00 3B
   262)      4357.4  Rx         04B0  8  27 10 27 10 27 10 27 10
   263)      4371.2  Rx         0210  7  FF FF 30 68 90 00 3C
   264)      4371.4  Rx         04B0  8  27 10 27 10 27 10 27 10
   265)      4385.2  Rx         0210  7  FF FF 30 68 90 00 3D
   266)      4385.4  Rx         04B0  8  27 10 27 10 27 10 27 10
   267)      4386.9  Rx         0305  8  00 00 00 00 00 02 00 00
   268)      4399.2  Rx         0210  7  FF FF 30 68 90 00 3E
   269)      4399.4  Rx         04B0  8  27 10 27 10 27 10 27 10
   270)      4411.9  Rx         0460  8  03 E0 00 00 C0 00 00 00
   271)      4413.2  Rx         0210  7  FF FF 30 68 90 00 3F
   272)      4413.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   273)      4426.7  Rx         0301  8  00 00 0D AA 00 6D 0A BE
   274)      4427.2  Rx         0210  7  FF FF 30 68 90 00 40
   275)      4427.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   276)      4441.3  Rx         0210  7  FF FF 30 68 90 00 41
   277)      4441.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   278)      4446.4  Rx         0311  2  00 00
   279)      4446.6  Rx         0263  6  00 00 00 8A 03 00
   280)      4455.2  Rx         0210  7  FF FF 30 68 90 00 42
   281)      4455.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   282)      4467.3  Rx         0302  8  00 00 00 00 0E 37 00 00
   283)      4469.2  Rx         0210  7  FF FF 30 68 90 00 43
   284)      4469.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   285)      4483.3  Rx         0210  7  FF FF 30 68 90 00 44
   286)      4483.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   287)      4497.3  Rx         0210  7  FF FF 30 68 90 00 45
   288)      4497.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   289)      4507.3  Rx         0303  8  0E 37 00 00 00 00 01 00
   290)      4511.3  Rx         0210  7  FF FF 30 68 90 00 46
   291)      4511.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   292)      4511.6  Rx         0023  1  40
   293)      4511.9  Rx         0460  8  03 E0 00 00 C0 00 00 00
   294)      4525.3  Rx         0210  7  FF FF 30 68 90 00 47
   295)      4525.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   296)      4529.4  Rx         0408  8  00 01 00 00 00 00 00 00
   297)      4539.3  Rx         0210  7  FF FF 30 68 90 00 48
   298)      4539.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   299)      4546.5  Rx         0310  3  00 00 00
   300)      4546.7  Rx         0264  8  00 00 00 00 00 00 00 00
   301)      4547.1  Rx         0304  8  00 00 00 00 0A AB 0A D1
   302)      4553.3  Rx         0210  7  FF FF 30 68 90 00 49
   303)      4553.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   304)      4567.3  Rx         0210  7  FF FF 30 68 90 00 4A
   305)      4567.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   306)      4581.3  Rx         0210  7  FF FF 30 68 90 00 4B
   307)      4581.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   308)      4587.2  Rx         0305  8  00 00 00 00 00 02 00 00
   309)      4595.3  Rx         0210  7  FF FF 30 68 90 00 4C
   310)      4595.5  Rx         04B0  8  27 10 27 10 27 10 27 10
   311)      4609.3  Rx         0210  7  FF FF 30 68 90 00 4D
   312)      4609.6  Rx         04B0  8  27 10 27 10 27 10 27 10
   313)      4611.5  Rx         0460  8  03 E0 00 00 C0 00 00 00
   314)      4623.3  Rx         0210  7  FF FF 30 68 90 00 4E
   315)      4623.6  Rx         04B0  8  27 10 27 10 27 10 27 10
   316)      4626.8  Rx         0301  8  00 00 0D AB 00 6D 0A BE
   317)      4637.3  Rx         0210  7  FF FF 30 68 90 00 4F
   318)      4637.6  Rx         04B0  8  27 10 27 10 27 10 27 10
   547)      5747.0  Rx         0310  3  00 00 00
   548)      5747.3  Rx         0264  8  00 00 00 00 00 00 00 00
   549)      5748.8  Rx         0304  8  0E 37 00 00 0A AB 0A D1
   550)      5758.6  Rx         0210  7  FF FF 30 68 90 00 9F
   551)      5758.8  Rx         04B0  8  27 10 27 10 27 10 27 10
   552)      5772.5  Rx         0210  7  FF FF 30 68 90 00 A0
   553)      5772.8  Rx         04B0  8  27 10 27 10 27 10 27 10
   554)      5786.6  Rx         0210  7  FF FF 30 68 90 00 A1
   555)      5786.8  Rx         04B0  8  27 10 27 10 27 10 27 10
   556)      5788.5  Rx         0305  8  00 00 01 00 00 02 00 00
   557)      5800.6  Rx         0210  7  FF FF 30 68 90 00 A2
   558)      5800.8  Rx         04B0  8  27 10 27 10 27 10 27 10
   559)      5809.0  Rx         0460  8  03 E0 00 00 C0 00 00 00
   560)      5814.6  Rx         0210  7  FF FF 30 68 90 00 A3
   561)      5814.8  Rx         04B0  8  27 10 27 10 27 10 27 10
   562)      5828.3  Rx         0301  8  00 05 0D 95 00 6D 0A BE
   563)      5828.6  Rx         0210  7  FF FF 30 68 90 00 A4
   564)      5828.8  Rx         04B0  8  27 10 27 10 27 10 27 10
   565)      5842.6  Rx         0210  7  FF FF 30 68 90 00 A5
   566)      5842.8  Rx         04B0  8  27 10 27 10 27 10 27 10
   567)      5847.0  Rx         0311  2  00 00
   568)      5847.3  Rx         0263  6  00 00 1D 90 0A 00
   569)      5856.6  Rx         0210  7  FF FF 30 68 90 00 A6
   570)      5856.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   571)      5868.3  Rx         0302  8  00 00 00 00 09 6E 09 24
   572)      5870.6  Rx         0210  7  FF FF 30 68 90 00 A7
   573)      5870.8  Rx         04B0  8  27 10 27 10 27 10 27 10
   574)      5884.6  Rx         0210  7  FF FF 30 68 90 00 A8
   575)      5884.8  Rx         04B0  8  27 10 27 10 27 10 27 10
   576)      5898.6  Rx         0210  7  FF FF 30 68 90 00 A9
   577)      5898.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   578)      5908.8  Rx         0023  1  40
   579)      5909.1  Rx         0460  8  03 E0 00 00 C0 00 00 00
   580)      5909.3  Rx         0303  8  11 32 04 B0 16 01 00 00
   581)      5912.6  Rx         0210  7  FF FF 30 68 90 00 AA
   582)      5912.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   583)      5926.7  Rx         0210  7  FF FF 30 68 90 00 AB
   584)      5926.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   585)      5940.6  Rx         0210  7  FF FF 30 68 90 00 AC
   586)      5940.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   587)      5947.1  Rx         0310  3  04 00 02
   588)      5947.4  Rx         0264  8  01 00 00 00 00 00 00 00
   589)      5948.9  Rx         0304  8  0E 37 00 00 0A AB 0A D1
   590)      5954.6  Rx         0210  7  FF FF 30 68 90 00 AD
   591)      5954.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   592)      5968.6  Rx         0210  7  FF FF 30 68 90 00 AE
   593)      5968.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   594)      5982.7  Rx         0210  7  FF FF 30 68 90 00 AF
   595)      5982.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   596)      5988.7  Rx         0305  8  00 00 01 00 00 02 00 00
   597)      5996.7  Rx         0210  7  FF FF 30 68 90 00 B0
   598)      5996.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   599)      6008.3  Rx         0300  8  03 0B 0E 4D 44 02 01 00
   600)      6008.6  Rx         0460  8  03 E0 00 00 C0 00 00 00
   601)      6008.8  Rx         0306  8  00 00 00 00 00 00 00 00
   602)      6010.7  Rx         0210  7  FF FF 30 68 90 00 B1
   603)      6010.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   604)      6024.7  Rx         0210  7  FF FF 30 68 90 00 B2
   605)      6024.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   606)      6027.6  Rx         0408  8  00 01 00 00 00 00 00 00
   607)      6028.5  Rx         0301  8  00 09 0D A3 00 6D 0A BE
   608)      6038.7  Rx         0210  7  FF FF 30 68 90 00 B3
   609)      6039.0  Rx         04B0  8  27 10 27 10 27 10 27 10
   610)      6047.1  Rx         0311  2  00 00
   611)      6047.3  Rx         0263  6  00 00 1D 91 0B 00
   612)      6052.7  Rx         0210  7  FF FF 30 68 90 00 B4
   613)      6052.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   614)      6066.7  Rx         0210  7  FF FF 30 68 90 00 B5
   615)      6066.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   616)      6068.7  Rx         0302  8  00 00 00 00 09 6E 09 24
   617)      6080.7  Rx         0210  7  FF FF 30 68 90 00 B6
   618)      6080.9  Rx         04B0  8  27 10 27 10 27 10 27 10
   619)      6094.7  Rx         0210  7  FF FF 30 68 90 00 B7
   620)      6095.0  Rx         04B0  8  27 10 27 10 27 10 27 10
   621)      6108.3  Rx         0023  1  40
   622)      6108.6  Rx         0460  8  03 E0 00 00 C0 00 00 00
   623)      6108.8  Rx         0210  7  FF FF 30 68 90 00 B8
   624)      6109.1  Rx         0303  8  11 32 04 B0 16 01 00 00
   625)      6109.3  Rx         04B0  8  27 10 27 10 27 10 27 10
   626)      6122.7  Rx         0210  7  FF FF 30 68 90 00 B9
   627)      6123.0  Rx         04B0  8  27 10 27 10 27 10 27 10
   628)      6136.7  Rx         0210  7  FF FF 30 68 90 00 BA
   629)      6137.0  Rx         04B0  8  27 10 27 10 27 10 27 10     ####### KEY START
  1932)     12450.6  Rx         0311  2  00 00
  1933)     12450.8  Rx         0263  6  00 00 1D 91 2B 00
  1934)     12454.1  Rx         0210  7  FF FF 30 20 90 00 7D
  1935)     12454.4  Rx         04B0  8  27 10 27 10 27 10 27 10
  1936)     12468.2  Rx         0210  7  FF FF 30 20 90 00 7E
  1937)     12468.4  Rx         04B0  8  27 10 27 10 27 10 27 10
  1938)     12475.1  Rx         0302  8  00 00 00 00 09 6E 09 24
  1939)     12482.2  Rx         0210  7  FF FF 30 20 90 00 7F
  1940)     12482.4  Rx         04B0  8  27 10 27 10 27 10 27 10
  1941)     12494.6  Rx         0023  1  40
  1942)     12494.9  Rx         0460  8  03 E0 00 00 00 00 00 00
  1943)     12496.2  Rx         0210  7  FF FF 30 20 90 00 80
  1944)     12496.4  Rx         04B0  8  27 10 27 10 27 10 27 10
  1945)     12510.2  Rx         0210  7  FF FF 30 20 90 00 81
  1946)     12510.4  Rx         04B0  8  27 10 27 10 27 10 27 10
  1947)     12515.5  Rx         0303  8  11 32 04 B0 16 01 00 00
  1948)     12521.3  Rx         0408  8  00 01 00 00 00 00 00 00
  1949)     12524.2  Rx         0210  7  FF FF 30 20 90 00 82
  1950)     12524.4  Rx         04B0  8  27 10 27 10 27 10 27 10
  1951)     12538.2  Rx         0210  7  FF FF 30 20 90 00 83
  1952)     12538.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1953)     12550.5  Rx         0310  3  04 00 06
  1954)     12550.8  Rx         0264  8  01 00 00 00 00 00 00 00
  1955)     12552.2  Rx         0210  7  FF FF 30 20 90 00 84
  1956)     12552.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1957)     12555.7  Rx         0304  8  0E 37 00 00 0A AB 0A D1
  1958)     12566.2  Rx         0210  7  FF FF 30 20 90 00 85
  1959)     12566.4  Rx         04B0  8  27 10 27 10 27 10 27 10
  1960)     12580.2  Rx         0210  7  FF FF 30 20 90 00 86
  1961)     12580.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1962)     12594.2  Rx         0210  7  FF FF 30 20 90 00 87
  1963)     12594.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1964)     12594.7  Rx         0460  8  03 E0 00 00 00 00 00 00
  1965)     12595.4  Rx         0305  8  00 00 01 00 00 02 00 00
  1966)     12608.3  Rx         0210  7  FF FF 30 20 90 00 88
  1967)     12608.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1968)     12622.3  Rx         0210  7  FF FF 30 20 90 00 89
  1969)     12622.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1970)     12635.1  Rx         0301  8  00 0A 0D A0 00 6D 0A BE
  1971)     12636.2  Rx         0210  7  FF FF 30 20 90 00 8A
  1972)     12636.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1973)     12650.3  Rx         0210  7  FF FF 30 20 90 00 8B
  1974)     12650.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1975)     12650.7  Rx         0311  2  00 00
  1976)     12651.3  Rx         0263  6  00 00 1D 91 2C 00
  1977)     12664.3  Rx         0210  7  FF FF 30 20 90 00 8C
  1978)     12664.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1979)     12675.2  Rx         0302  8  00 00 00 00 09 6E 09 24
  1980)     12678.3  Rx         0210  7  FF FF 30 20 90 00 8D
  1981)     12678.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1982)     12692.3  Rx         0210  7  FF FF 30 20 90 00 8E
  1983)     12692.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1984)     12694.2  Rx         0023  1  40
  1985)     12694.5  Rx         0460  8  03 E0 00 00 00 00 00 00
  1986)     12706.3  Rx         0210  7  FF FF 30 20 90 00 8F
  1987)     12706.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1988)     12715.6  Rx         0303  8  11 32 04 B0 16 01 00 00
  1989)     12720.3  Rx         0210  7  FF FF 30 20 90 00 90
  1990)     12720.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  1991)     12734.3  Rx         0210  7  FF FF 30 20 90 00 91
  1992)     12734.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1993)     12748.3  Rx         0210  7  FF FF 30 20 90 00 92
  1994)     12748.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  1995)     12750.7  Rx         0310  3  04 00 06
  1996)     12751.0  Rx         0264  8  01 00 00 00 00 00 00 00
  1997)     12755.9  Rx         0304  8  0E 37 00 00 0A AB 0A D1
  1998)     12762.3  Rx         0210  7  FF FF 30 20 90 00 93
  1999)     12762.5  Rx         04B0  8  27 10 27 10 27 10 27 10
  2000)     12776.3  Rx         0210  7  FF FF 30 20 90 00 94
  2001)     12776.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  2002)     12790.4  Rx         0210  7  FF FF 30 20 90 00 95
  2003)     12790.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  2004)     12794.2  Rx         0460  8  03 E0 00 00 00 00 00 00
  2005)     12795.4  Rx         0305  8  00 00 01 00 00 02 00 00
  2006)     12804.4  Rx         0210  7  FF FF 30 20 90 00 96
  2007)     12804.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  2008)     12818.3  Rx         0210  7  FF FF 30 20 90 00 97
  2009)     12818.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  2010)     12832.4  Rx         0210  7  FF FF 30 20 90 00 98
  2011)     12832.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  2012)     12835.3  Rx         0301  8  00 0A 0D A0 00 6D 0A BE
  2013)     12846.4  Rx         0210  7  FF FF 30 20 90 00 99
  2014)     12846.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  2015)     12850.6  Rx         0311  2  00 00
  2016)     12851.3  Rx         0263  6  00 00 1D 91 2D 00
  2017)     12860.4  Rx         0210  7  FF FF 30 20 90 00 9A
  2018)     12860.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  2019)     12874.4  Rx         0210  7  FF FF 30 20 90 00 9B
  2020)     12874.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  2021)     12875.3  Rx         0302  8  00 00 00 00 09 6E 09 24
  2022)     12888.4  Rx         0210  7  FF FF 30 20 90 00 9C
  2023)     12888.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  2024)     12893.7  Rx         0023  1  40
  2025)     12894.2  Rx         0460  8  03 E0 00 00 00 00 00 00
  2026)     12902.4  Rx         0210  7  FF FF 30 20 90 00 9D
  2027)     12902.7  Rx         04B0  8  27 10 27 10 27 10 27 10
  2028)     12915.8  Rx         0303  8  11 32 04 B0 16 01 00 00
  2029)     12916.4  Rx         0210  7  FF FF 30 20 90 00 9E
  2030)     12916.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  2031)     12930.4  Rx         0210  7  FF FF 30 20 90 00 9F
  2032)     12930.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  2033)     12944.4  Rx         0210  7  FF FF 30 20 90 00 A0
  2034)     12944.7  Rx         04B0  8  27 10 27 10 27 10 27 10
  2035)     12950.7  Rx         0310  3  04 00 06
  4828)     26455.3  Rx         0311  2  00 00                                ###############Driving
  4829)     26456.0  Rx         0263  6  00 00 1D 91 71 00
  4830)     26462.0  Rx         0210  7  FF FF 30 20 90 00 65
  4831)     26462.3  Rx         04B0  8  27 10 27 10 27 10 27 10
  4832)     26465.2  Rx         0023  1  40
  4833)     26465.5  Rx         0460  8  03 E0 00 00 00 00 00 00
  4834)     26476.0  Rx         0210  7  FF FF 30 20 90 00 66
  4835)     26476.3  Rx         04B0  8  27 10 27 10 27 10 27 10
  4836)     26488.5  Rx         0302  8  00 00 00 00 09 6E 09 24
  4837)     26490.0  Rx         0210  7  FF FF 30 20 90 00 67
  4838)     26490.3  Rx         04B0  8  27 10 27 10 27 10 27 10
  4839)     26504.1  Rx         0210  7  FF FF 30 20 90 00 68
  4840)     26504.3  Rx         04B0  8  27 10 27 10 27 10 27 10
  4841)     26507.6  Rx         0408  8  00 01 00 00 00 00 00 00
  4842)     26518.1  Rx         0210  7  FF FF 30 20 90 00 69
  4843)     26518.3  Rx         04B0  8  27 10 27 10 27 10 27 10
  4844)     26528.9  Rx         0303  8  11 32 04 B0 16 01 00 00
  4845)     26532.1  Rx         0210  7  FF FF 30 20 90 00 6A
  4846)     26532.3  Rx         04B0  8  27 10 27 10 27 10 27 10
  4847)     26546.1  Rx         0210  7  FF FF 30 20 90 00 6B
  4848)     26546.3  Rx         04B0  8  27 10 27 10 27 10 27 10
  4849)     26555.4  Rx         0310  3  04 00 06
  4850)     26555.6  Rx         0264  8  01 00 00 00 00 00 00 00
  4851)     26560.1  Rx         0210  7  FF FF 30 20 90 00 6C
  4852)     26560.3  Rx         04B0  8  27 10 27 10 27 10 27 10
  4853)     26565.0  Rx         0460  8  03 E0 00 00 00 00 00 00
  4854)     26569.0  Rx         0304  8  0E 37 00 00 0A AC 0A D2
  4855)     26574.1  Rx         0210  7  FF FF 30 20 90 00 6D
  4856)     26574.3  Rx         04B0  8  27 10 27 10 27 10 27 10
  4857)     26588.1  Rx         0210  7  FF FF 30 20 90 00 6E
  4858)     26588.3  Rx         04B0  8  27 10 27 10 27 10 27 10
  4859)     26602.1  Rx         0210  7  FF FF 30 20 90 00 6F
  4860)     26602.3  Rx         04B0  8  27 10 27 10 27 10 27 10
  4861)     26608.7  Rx         0305  8  00 00 01 00 00 02 00 00
  5321)     28885.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  5322)     28890.0  Rx         0302  8  00 00 00 00 0E 37 00 00
  5323)     28899.4  Rx         0210  7  FF FF 30 68 90 00 13
  5324)     28899.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  5325)     28913.4  Rx         0210  7  FF FF 30 68 90 00 14
  5326)     28913.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  5327)     28927.4  Rx         0210  7  FF FF 30 68 90 00 15
  5328)     28927.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  5329)     28930.4  Rx         0303  8  0E 37 00 00 00 00 01 00
  5330)     28941.4  Rx         0210  7  FF FF 30 68 90 00 16
  5331)     28941.6  Rx         04B0  8  27 10 27 10 27 10 27 10
  5332)     28954.7  Rx         0310  3  00 00 00
  5333)     28955.0  Rx         0264  8  00 00 00 00 00 00 00 00
  5334)     28955.4  Rx         0210  7  FF FF 30 68 90 00 17
  5335)     28955.7  Rx         04B0  8  27 10 27 10 27 10 27 10
  5336)     28969.4  Rx         0210  7  FF FF 30 68 90 00 18
  5337)     28969.7  Rx         04B0  8  27 10 27 10 27 10 27 10
  5338)     28970.5  Rx         0304  8  00 00 00 00 0A AC 0A D2
  5339)     28983.4  Rx         0210  7  FF FF 30 68 90 00 19
  5340)     28983.7  Rx         04B0  8  27 10 27 10 27 10 27 10
  5341)     28997.4  Rx         0210  7  FF FF 30 68 90 00 1A
  5342)     28997.7  Rx         04B0  8  27 10 27 10 27 10 27 10
  5343)     29010.3  Rx         0305  8  00 00 00 00 00 02 00 00
  5344)     29011.4  Rx         0210  7  FF FF 30 68 90 00 1B
  5372)     29151.8  Rx         04B0  8  27 10 27 10 27 10 27 10
  5373)     29154.8  Rx         0310  3  00 00 00
  5374)     29155.1  Rx         0264  8  00 00 00 00 00 00 00 00
  5375)     29165.5  Rx         0210  7  FF FF 30 68 90 00 26
  5376)     29165.8  Rx         04B0  8  27 10 27 10 27 10 27 10
  5377)     29170.5  Rx         0304  8  00 00 00 00 0A AC 0A D2
  5378)     29179.5  Rx         0210  7  FF FF 30 68 90 00 27                  ###########KEY OFF
Warlock
whoop whoop!
So cool you managed to do this. Grats!
BauDemo
Congratulations!!!
Excellent work!
Any luck with the charging?
You have my number... so feel free to call if you need help.
Also maybe you want to make a room for the relays for the chademo charging?
motorulf
Thank you!  :)
Now i need to open up the BMS box again and add some diodes to keep the contactor coil's flyback currents from destroying the driver transistors.
Also the current sensor is giving me a lot of strange values, need to check that guy again, make sure it is connected right. Most probably it is not...   haha
Without it things still works, but i don't get an accurate SOC meter and the extra safety it provides.
I have pulled charging cables out where the cooling fan used to be, there i have connected a brusa charger.
I will try to get the internal charger working, but to do that i need to add a lot of code into the "BMS". Right now i dont have the energy for it and its cold in my garage...
But everything is prepared, and for CHAdeMO aswell   8)  well... it´s just charging cables and an enable signal cable. The rest is planned for the future.
When the battery is in the car again, mounted more permanently, i need to build a water heater for the battery.
I had -14° outside last night, so that is more important than fast charging. The winter is coming, they say...
