BMS oppdatering
Startet av Jørgen L, torsdag 16. august 2018, klokken 11:21
Jørgen L
I service historikken på bilen står det at BMS og BMS-sikkerhet er oppdatert, og at styringsenhet er omprogrammert den 30.07.18. Har bilen da den siste BMS oppdateringen som er ute fra renault?
Bilen er en  Zoe intens easy Charge 22kw 2015.
Beklager hvis det blir endel poster for tiden.
minibiti
It depends a bit on when the BMS was updated exactly. If it has been done in the last 6 months, it should have the latest version.
When you say you have a Zoe Intens Easy Charge 22kw 2015, do you mean you have a R240?
I am asking because many people are confused between 22kW and 22kWh...
22kW would refer to the charging capabilities of the car which would then mean you have a R240
22kWh would refer to the capacity of the battery pack in which case you have a Q210
The Q210 is the older version, supports up to 43 kW when charging, has a 22 kWh battery pack and the old, less efficient Continental engine.
The R240 is a bit more recent, sold after mid 2015, support only 22 kW when charging, has a 23.3 kWh battery pack and the newer more efficient Renault engine.
Both engine have roughly the same power output.
Oslo
2020 Zoe Intens R135 (Jan 2020 - present)
Jørgen L
Bilen min ble førstegangs registrert 29.06.2015.
Så da er det vel den siste utgaven av de med forbedringene.
Jørgen L
Jørgen L
Siste BMS oppdatering bilen har er 0854, har det kommet noen nyere versjoner?
minibiti
That's the one I have as well and when I went to MF to service my car in July, I was told this was the latest available version for the R240.
Oslo
pudderjagar
Eg har høyrt rykte om at da er ny software etter versjon 0854. Eg skal inn på oppdatering om 2 dager så hvis eg får bilen ut igjen innen normal tid så skal eg gje ei oppdatering.
Kjører:
Nissan e-nv200 Evalia (24kwh)
