Repair of charger
Startet av OZ1KNT, lørdag 12. november 2016, klokken 10:07
OZ1KNT
Hi'
I write this in english for "maby" a better understanding :-)
When my charger took the way to the land of death Think chargers, i decided to make some research of what went wrong.
I now have examined 3 diffrent chargers and 2 of them is working again, the last one is still on the workbench but i'm shure it will work again when new parts arrive shortly here.
It seems that the blow/bad components is allmost the same in each case, so there is a pattern in the fault.
So if any off you out there have some defect chargers that you maby will give a chance to work again, sent me a message.
It will be a "nonprofit" project where i look in each case to see if it is possible to repair it and what the cost will be.
Any way thank's for the backup in here, and let us keep up these nice cars running on the street and not ending up on a junkyard...
Best regard
Jesper
Well done!
How many do you want?
Have 10 chargers I can bring you 22 des.
OZ1KNT
That sounds great, will be happy to take a look on them.
I will be able to meet you some where i DK at 22 december, so lets arrange something.Br.
Jesper
Great!
Actually we will be south on E45 at 11:00 hrs on the 23rd des. Maybe Bilka Kolding?
OZ1KNT
Sounds great, i will meet you there.
let's keep in touch the days up to the 23. dec.
You can allways call me on phone
Br.
Jesper
rzepon
Hello
I have problem with my charger Actia Think 433 1004 , P104090E N'00286
On the last few charging charger didn't start at first second but after 10-20 minutes, at this moment charging  don't start, all fuses are OK, 230V is comming to charger and 119v from batteries is connect , NikoMeter didn't see this values only showing temperature in three points, inside charger all looks perfect any defects, fuses OK, I checked four diodes BYW 99P200 in one way has got 12-16kohm, I haven't shemat this charger.
Chris
rzepon
Hello
Charger working again !!! I changed two opotoelements SFH6136 inside charger .
By
Chris
Yeyeye
Tror min siste lader er på tur til å dø, bilen stod plutselig med "fullt" batteri litt for tidlig her i ettermiddag. Flere som har byttet slike optokoblere med godt resultat?
https://m.elfadistrelec.no/search?q=SFH6136&submit=
Trondheim
Think classic 2002,Think classic 2001(tidligere Gråtass)
Nissan Leaf 2016 30kWh
Yeyeye
Da ble denne aktuell igjen, noen flere som har ærfaring med rep av gamle uten synlige feil?
AR
Trondheim
Jesper ble dessverre umulig å kontakte etter at han fikk mine beste 10 ladere. Heldigvis har jeg enda noen som bør være reparerbare.
Yeyeye
Ser det står gjest munder profilen hans her også, synd han forsvant.
AR
Trondheim
ebye
Jeg har to ladere som ser uskadet ut innvendig. alle tre utvendige vifter er OK. Jeg har testet de begge på en bil som lader og oppfører seg normalt med sin egen lader.
Når 230V kobles til, starter vannpumpen og 12V-laderen i bilen begynner å lade; Nikkometer viser 13,8V, ladelyset i dashbordet starter å blunke, men spenning på batteriet er uforandret og strømforbruket ligger på -0,09 til -0,1 kW hvor det normalt lader med +1,8 kW og bilen tar ikke lading. Noen ganger har det hendt at bilen har stått tilkoblet og ingenting har skjedd før etter tyve minutter og den har startet lading i noen få minutter før lading stopper, 12V-lader har vært i virksomhet sammen med vannpumpe.
Siden jeg plutselig har to ladere med samme symptom lurer jeg på om det er en kjent feil og om det er noen enkle grep å bytte noe innmat?
Rav4_EV
Dersom de ikke er ødelagt av vanninntrenging som gir brent kretskort er det effektfaktorkorrigeringen som har tatt kvelden. Logikken finner du på printkortet som står på høykant. Denne styrer boostkonverteren i inngangen. Dette systemet kollapser når laderen får for stort tap i forsyningen som skjøteledning, dårlig defakontakt eller feil i støyfilteret i den grå boksen.
22' X Plaid
